Robert Kenney
Super Moderator
I rebuilt the engine in my Scout in 2005. It now has about 7000 miles on it and I was wondering how the lifters were wearing. It also had an odd tick once in a while usually while some what cold after running for 5 minutes. It would be dead quiet @500 rpm and above 700 but would some times tick a bit between 550-700 until I would drive it for 10 minutes or so.
I used what were supposed to be elgine lifters but they came in an unmarked box so I am not sure. Lifters are supposed to have a very slightly convex contour ground in to the cam contact face to facilitate rotation and proper wear. These did not!!!
I was uneasy about that from the get-go
sooooooo, I decided to loosen up the rocker assembly and have a look at the lifters for any abnormal wear. This is what I found. The rectangular shiny wear pattern says to me they are not turning and this is the same more or less on all except one(second to last image). They also have a slight line impression in the center of the pattern. The pattern should be even and circular across the face of the lifter..
I will be checking the hardness of the face tomorrow. Imo it should be around 50-55 rockwell c scale. At least all of the GM stuff I have done over the years has been. I have always used valvoline vr1 (1300 ppm zinc , 1200 ppm phosphorus) in my flat tappet motors and never had a problem even with 330# over the nose(not this engine).
Any suggestions would be appreciated.
Robert
I was uneasy about that from the get-gosooooooo, I decided to loosen up the rocker assembly and have a look at the lifters for any abnormal wear. This is what I found. The rectangular shiny wear pattern says to me they are not turning and this is the same more or less on all except one(second to last image). They also have a slight line impression in the center of the pattern. The pattern should be even and circular across the face of the lifter..
Robert
I forgot to mention that I had thte cam reground by schneider a bit bigger, and installed .050 longer pushrods to comp for smaller base circle after regrind. I have .075 lifter preload.
