Not able to get Dana 20 into N or 4-LO
Rentalman
Active member
Good evening everyone. On my 74 Scout II that I've restored, I am unable to get the Dana 20 T-Case into N or 4-low. I have no problem getting into 2-hi to 4-hi and back to 2-hi while rolling. I've tried getting into N or 4-low with trani in N rolling, in D, 2 or 1 slowly creeping. The shift lever will not budge. While testing becasue I'm in my driveway or on my street I do not have the manual hubs in 4x4. I've inspected from underneath. The shift lever is not hitting anything. The trani is a rebuilt TF727. A mechanic from my prior job and I rebuilt the T-Case with a Novak rebuild kit. Upgraded parts were new bearings, seals, intermediate shaft, stiffer springs and new detent balls. The shift rails were polished smooth with emory cloth to remove scratches. The outer case was sandblasted and thoroughly cleaned in a hot water/solvent parts washing tank. As I recall when I mounted the T-case to the transmission, no drivelines attached I was able to shift through all the gears. When I rebuilt/restored this Scout it was non running. Unfortunately I don't know if anything worked when I got it. I went straight to rebuilding it/restoring it.
I've have tried with the engine off, no go. I was under the Scout again after my post. When I push forward on the gear selector from below, the link control has a pin on it that is supposed to slide between the guide. It looks like my link control pin is hitting the outer edge of the guide and it's not sliding in between. Maybe my shift rails aren't sliding correctly?
Those fantastic stiffer springs might be a cause.
Hi Winchested, if they are the issue. Would I be able to remove the plugs and swap out the springs with the t-case still installed.
That I'm not sure can't remember been awhile since I had one apart.
Id pull the single shifter and pivot and see if you can still shift each rail individually.
If so, twin stick upgrade!
If you can't pull the pin on the shifter pivot, time to drill the hole in the trans tunnel to pull it out.
Pretty typical of a automatic Scout. Takes a little bit to break in after a rebuild, and the engine needs to be either off in neutral or from park to reverse to get the gears to line up.
Zaed, thanks for the reply. As usual part of the problem was me. I got underneath the Scout yesterday and was pulling the shift lever towards 4-L. The guide pin on the link control was hitting up against the T-Case control guide. I could not push the 4x4 lever past that even from the cab. I was able to move it with my hand and get it centered in the guide and shift to 4-L. Why it was binding is because when I put the shift lever back together, I replaced the hose that slides on the Lever End Ball with a slightly thicker diameter. The top of the pin that takes a cotter pin to secure it to the link control for the front axle shift rail was binding up against that hose. I replaced the hose with a smaller diameter, now I can shift in 4L, N, 2H & 4H. Today I drove the Scout and was able to get it in 4-L. I tried various methods, but what worked was what you mentioned. Shut the engine off, push the lever into 4-L and restart the Scout. Thanks again Zaed and everyone else with their suggestions.
The engine stop method can certainly be a thing with the auto trans. Dealer salesmen were trained to demonstrate the 4x4 shifting with an auto trans using both hands simultaneously. One hand on the gear selector to slowly cycle between R-N-D-N-R and the other hand to work the case lever in the desired direction. This is only for getting out of 2Hi into N or 4Lo and then back to 2Hi. The 2-4 Hi range shifting is meant to be done on the fly. I'm glad you figured out your particular issue and that it was simple to remedy.
Thanks Scoutboy74. Prior to shutting the engine off I did try what you mentioned cycling thru the gears. No go. After it breaks in more maybe it will get easier. I'm just glad it works and I don't have to pull the T-Case out. On a great note I just scored another Dana 20 for $50. It's the same as my current one with 15 splines for the bullgear. Just incase I need a back up.
