Not able to get Dana 20 into N or 4-LO
Rentalman
Active member
Good evening everyone. On my 74 Scout II that I've restored, I am unable to get the Dana 20 T-Case into N or 4-low. I have no problem getting into 2-hi to 4-hi and back to 2-hi while rolling. I've tried getting into N or 4-low with trani in N rolling, in D, 2 or 1 slowly creeping. The shift lever will not budge. While testing becasue I'm in my driveway or on my street I do not have the manual hubs in 4x4. I've inspected from underneath. The shift lever is not hitting anything. The trani is a rebuilt TF727. A mechanic from my prior job and I rebuilt the T-Case with a Novak rebuild kit. Upgraded parts were new bearings, seals, intermediate shaft, stiffer springs and new detent balls. The shift rails were polished smooth with emory cloth to remove scratches. The outer case was sandblasted and thoroughly cleaned in a hot water/solvent parts washing tank. As I recall when I mounted the T-case to the transmission, no drivelines attached I was able to shift through all the gears. When I rebuilt/restored this Scout it was non running. Unfortunately I don't know if anything worked when I got it. I went straight to rebuilding it/restoring it.
I've have tried with the engine off, no go. I was under the Scout again after my post. When I push forward on the gear selector from below, the link control has a pin on it that is supposed to slide between the guide. It looks like my link control pin is hitting the outer edge of the guide and it's not sliding in between. Maybe my shift rails aren't sliding correctly?
Those fantastic stiffer springs might be a cause.
