Hi all,
this is maybe my 3rd thread on this "newly" rebuilt 304. It was done 11 yrs ago and sat while I finished the truck.
The motor has about 1500 miles on it and started making noise after a long highway trip after the motor had accrued about 500 miles.
I removed the timing cover and oil pan. The following pix are what I found. The counter weight adjacent to the #3 piston has some shiny parts to it where none of the others do. Again the motor is 11 years old and there is some oxidation but not on the shiny areas. Any thoughts if this could be making the noise?
Here are the pix:
https://picasaweb.google.com/107722218277971181704/crankmarks#
I have some video of the noise:
youtube - massachusetts2010's channel
I haven't pulled the motor to check on the rear cam bearing.
I do have great pressure (50 psi) using a drill at the head feeding the rockers, I do have both oil galley plugs behind the timing cover.
Thanks.
Here are the pix:
Thanks.
no pun intended. Do a quick once over. You would see it clear as day.
