Robert Kenney
Super Moderator
It is common to have to dress up a cam bearing id. It is a delicate hand operation that is only needed if the cam turns tight. Most of the time lubing, slipping in the cam and, working the cam around is enough.
which side is good & which side is bad?
Be sure the oil gallery plugs in the front Of the block are installed.
One on each side, behind the timing cover.
If one valve train is well lubed and the other is not, I'd check the plug on the non-lubed side.
By running it lean the tops of at least two pistons began to melt. Still ran awesome and had awesome power but I never was happy with this engine anyway. The balance job sucked, rings were at max gap when I assembled it and I didn't get my zero deck that I asked for. So now we use another shop out of state and I get a dam good warranty with it.
probably detonated it some.
You got away without ripping the rings and bores up due to butting because the gaps were big. You really need to go big for this build and application. Always gap for the worst possible duty you expect to give it.
Did you have an engine oil cooler? 180-195f max when pushing it as a tow rig with high compression.
Did you see above normal coolant temps?
