Bill USN-1
F.I. Moderator
If you have no ping then you May want to bump the timing about 4-5°.
working on charging system, but also posting injector size chart. Still looking for some 5.7 injectors.
Edit.. Found somebut will get a data run with what I have first.
it seems a lot more responsive with the timing bump "
why? Your fuel looks pretty good. If you change injectors you'll have to tune fuel all over again.
Lots of potential from the motor if the timing is tuned correctly. Imo, ECM controlled timing is a must have with FI.
dang your up early for a Sunday.
Thanks for looking, it's running good when I down shifted to 2nd on some hill climbs. I talked with Jeff and he said 3,000 rpm is not to much for this engine.
it might have something to do with my new location!!
I just shipped out to the desert.
I'm currently in al udeid, qatar.
But only for 6mo this time.
