79 Scout w/345. Cannot get it to fire. Have checked and replaced wires. Am getting 12vdc at the positive side of the coil. Originally had points but bought new pertronix unit. Don't think it works since I am not getting an intermittent 12v signal at the negative side of coil when I rotate the distributor past a lobe or two. Have also installed points (0.016" gap). After a few days of working on it, realized we had a **edited** prestolite cap and a Holley rotor (banged on the head of cap when rotating). We've timed the bugger off of #8 more times than I care to remember. At one point we had it running very rough but timing light showed it 50 degrees retarded (like I feel now). Tried to re-time it and it never ran again. I've got intermittent signal on each plug wire as tested with inductor lead of timing light. New ground wire to block from battery. Tried 12v direct from battery to pos side of coil (actually resistor since we're trying with points). When I pull a plug and check the spark, there's a very weak spark. When I put a plug in the coil wire, there's several small sparks, not very easily seen. I am of the impression that if you're running a plug out of the coil, that baby should pop pretty good. I'm at wits end on what the issue is. Is it possible the wrong coil is being used...if so, what coil should be bought in order to use the Holley cap/rotor with points. If the pertronix unit is working properly by not cycling while the distributor shaft is spinning, can the same coil be used with it. Thanks for any thoughts. I'm at wits end on this one. Almost time to make some deep lake structure with this thing. One more thing, is it alright to install the condenser in the bracket along with the coil and connect it to the negative side of coil there, the wire connecting it to the points is a short, the ballast is simply on the other end of the wire?
