It seems like she is running ok but the idle is a little high @ around 800 rpm. The strange thing is that the timing is around 40 degrees retarded. I don't know how it could run this well with the timing that far off, but it seems to get worse when it is adjusted. Not sure how it will perform under load because we are still running the hot wire setup.
Now to the real question. The ignition wire going to the coil (by16) cennects to an orange wire that goes to the ignition module on the steering column. This orange wire was competely fried. Could this be an indication of another problem, like a bad module? I still don't see any resistance wire as it was described before so I am assuming I will need the ballast resistor and run the wiring as shown by the last .pdf sent by michael (thanks!)
bottom line should this issue be investigated further or just replace the wire and go for the long awaited test drive?
