Need a bit of help getting this thing firing
Ok, here is the update. The ballast resistor is gone, and things are back to what I believe to be stock form. There is one wire coming out of the wiring harness going to the coil. There is no b+ wire from the starter to the coil. The resistance between the coil and where that wire terminates at the plug on the firewall is only .3 ohms. Using suggestion from rk, we have jumpered 12v to the coil and get 12v across the coil with the points closed (in run position or start since no b+ feed). Wire from ignition is shorted or opened somewhere inside the firewall, not getting any voltage to coil through ignition wire. The points are opening and closing correctly, but there seems to be a very weak spark at the plugs seen by pulling a plug and grounding it out while starting. The timing was reset with #8 at tdc on the compression stroke as described in the thread from yesterday.
Robert,
should the 12v jumped directly to the coil enable enough spark to fire? According to the resistance checks and voltage checks to the + and - side of the coil, it is operating properly. We don't have the equipment available to test it as per michael's suggestion to verify proper coil output. Once we get it to fire, we can go back and re-wire the ignition to include the start and run circuits from the starter/ignition switch.
Robert's not "on" right now.
Run a jumper from the battery positive terminal to the coil positive terminal. Crank the engien over and if the coil is ok and dwell is set, it will run. That's a "hot wire" setup like us oldtimer's used when pop hid our car keys.
You can run b+ directly to the coil for maybe 5>10 minutes with the engine running before the points start turning red and blue from excessive heat (current). It it stalls, disconnect the hot wire quickly or the points will undergo meltdown real quick.
Robert,
There is no need for any fancy equipment to adequtely test they coils output potential. The rough rule of thumb is 40kv an inch in free air, so establish an aprox 1/2" gap between the cap end of the coil wire and ground. Turn the engine so the points are closed attach your b+ jumper and manually open the points with a non metallic object. If it will jump the 1/2" gap then your coil has enough power to start the engine. If it won't jump the 1/2" gap reduce it and try again until you get it to jump the gap each time you open the points. A 1/4" free air gap May or May not have enough oomph to start an engine depending on the a/f mix, spark plug gap, and actual cranking cyl pressure. The ability to jump a wide spark plug gap of .050 in free air only translates to an aprox voltage of 2kv no where near enough to start any engine.
Here is a pic of my "coil tester" used professionally for over 15 years to test all types of coils, old fashion canisters, coil in cap hei honda & toyota, "e" core, waste spark and even "dumb" coil on plug units.
I am starting to think this wiring is a real cluster. My frustration level is peaking right now. I would like to get things back to oem spec and proceed from there. Starting from the beginning is the way to go right now because I am just running in circles.
Does anyone have a wiring schematic for the ignition? When every wire in the harness is black then it makes tracing things a bit of a challenge. Also when there are wire nuts connecting the alternator to the wiring harness I am guessing they didnt take much care in making things factory. I am starting to think the ignition switch might be suspect.
This a portion of the electrical schematic...only for the ignition system for a '79 Scout II. That's the vehicle that originally described.
The wiring for a breaker point distributor/Scout II however has nothing in common with this schematic for the most part.
Why would you spend $400+ to put a new wiring harness in and expect any better results? If you can't rig a simple "hot wire" setup to provide current to run a breaker point system, then running a harness is certainly not something you are capable of doing! That takes one wire!
Make it run now with a points distributor and coil of the proper "value". It simply cannot be any easier to do.
  • 1979 Scout II Ignition Wiring.PDF
if you can't rig a simple "hot wire" setup to provide current to run a breaker point system, then running a harness is certainly not something you are capable of doing!
One would think it is just that easy. But like mentioned before, with a 12v "hot wire" setup, it isn't getting the spark to fire.
one would think it is just that easy. But like mentioned before, with a 12v "hot wire" setup, it isn't getting the spark to fire.
Which is why you need to test the coils output ability as I described above. That will prove out the coil and condenser's ability to provide adequate spark. If you can't generate a spark that will jump a 3/8" free air gap like that, then the coil or condenser is bad.
Thanks eric, we're going to test that coil and see if we can get it to jump a decent gap. If not, we'll have to try an upgraded version (accel or the like). According to michael, it should be a 1.4 - 1.8 ohm primary resistance and a local store has the 8140 which is a 1.4ohm primary.
Eric's redneck coil tester works fine for checking if a coil will "make a spark" at a single point in time. That can also be done using the distributor (if it is a breaker point version) in the vehicle as he pointed out.
A similar test can also be done "sometimes" regarding an electronic trigger distributor but ya better dam sure know how to do that or you will blow the electronics on an electronic ignition system. Normally that is done using a dedicated "trigger box"-type tester, though there can be redneck workarounds for that also...I have a few of those but I will not discuss that kinda stuff here as it always leads to parts damage when folks don't follow directions, then they blame me.
In the case of the various systems that IH used on sv engines, the ignition coil specs are virtually the same for all versions, whether breaker point trigger, a delco "mag pulse" trigger, a Holley gold box trigger, or a prestolite electronic trigger. That greatly simplifies stuff as "one coil fits all".
But that does not test a coil.
Testing a cannister-style coil involves several checks whether on the bench or installed onna vehicle:
1) disconnect all wires/harness from the coil, it must not be connected to anything.
2) measure the primary resistance with a dvom (follow instructions for your device), multimeter, or ohmmeter...one probe on the positive terminal, one probe on the negative terminal, polarity is not important at that point. Make the reading and record. Repeat it. Repeat it again. If ya get the same reading three times in a row, then that is the value.
3) measure the secondary resistance with the same instrument, one probe engaging the secondary terminal (center terminal on the coil in the pic), and the other probe on either the positive terminal or the secondary terminal (doesn't matter which on this type of coil). Repeat three times and record.
4) if both resistance tests are within spec (typical 1.4>1.8 ohms primary, 6.0k>9.0k ohms secondary), the coil will fire a plug with an engine running when the coil is "cold".
5) reinstall the coil and rig an additional "air gap" of approximately 1/4" between the coil wire and the secondary terminal with the engine running at idle speed. Let it run a minimum of 15 minutes or until the engine stalls or starts blubbering. If it don't blubber/stall, the coil is good under heat load running at full output potential.
If it blubbers/stalls/spark is intermittent, then the coil is removed and gets smashed with a hammer and discarded as ng so it can't be mistakenly re-used.
A cannister coil like is used on most all oem automotive apps up to the advent of the "e-core" coil design will normally fail only after running under load (which means it gets hot internally) for a period of time and performance begins to diminish to the point it can't produce output for all cylinders as designed. Some mechanics refer to that as a "coil breakdown"...random misfire, then steady misfire, then no spark at all or too weak to ionize the plug gap under cylinder pressure.
The yellow accel coil in the tester picture I posted shows excellent output, and I know what it's max output is in kv because it was also tested before hand on an engine analyzer w/oscilloscope. In that pic, the coil is cold.
That coil tester has a heat position which is then engaged for five minutes, after which the test is repeated. That is not long enough on most "high turn" coils to create heat load to test the coil under engine operating conditions. So I heat for at least 30 minutes, checking output periodically.
The accel coil in the pic begins to break down at 12 minutes (yes this failure point is repeatable), output kv is reduced by approximately one half in free air. That means the coil will not fire a plug under compression load in a cylinder when dosed with the intake charge "mix"...yet it still sparks on the tester. You can also hear the spark output begin to deteriorate.
At 20 minutes output kv goes away completely...the coil is now dead and useless. Primary resistance test show "open circuit/winding". Let it sit three hours and guess what...it comes back to life and the cycle begins again...day after day after day!
So yes...that yellow coil tested "good"...but it ain't worth shit. Why???? Because all the insulating oil leaked out though the shittee "seal" found under the secondary female terminal. But that is just one of several failure modes that a cannister-type coil can develop.
The accel 8140 has a 9.2 k-ohm secondary, will the extra 200ohms have much of an effect? I was unable to find an accel that spec'd to 1.6 ohms like michael's, the closest I could find was the 1.4 ohm one (they also had a 0.7 ohm line).
Does anyone have an actual part number for the points that should be in the Holley distributor...or better yet, a picture? I don't know if it matters, but we're just matching what was in there...and we're not very confident the po cared about compatibility.
Any coil with a primary resistance of between 1.4 and 1.8ohms is fine, the secondary resistance is only a function of "turn ratio" and that has nothing to do with what you are playing with as long secondary winding is not open or is not down below about 4kohms.
Pull the points out, clean and lay on the bench with no condenser connected. The points are simply a switch. Resistance across the point set should be under 2 ohms, the lower the better but will never read "zero" as any point set will exhibit a nominal resistance of at least 0.2 ohms.
the accel 8140 has a 9.2 k-ohm secondary, will the extra 200ohms have much of an effect? I was unable to find an accel that spec'd to 1.6 ohms like michael's, the closest I could find was the 1.4 ohm one (they also had a 0.7 ohm line).
The curved and straight Holley points are very different and you can't bolt the wrong set in.
Holley straight points
http://www.partsamerica.com/productdetail.aspx?mfrcode=nie&mfrpartnumber=ff3h&parttype=199&ptset=a
Which if you click the see all vehicles this fits you will see they are the same as 6cyl fords
Holley curved points
http://www.partsamerica.com/productdetail.aspx?mfrcode=nie&mfrpartnumber=ih5&parttype=199&ptset=a
Which are an IH only part.
In case someone tried to get creative the prestolite
http://www.partsamerica.com/productdetail.aspx?mfrcode=nie&mfrpartnumber=ih6&parttype=199&ptset=a
And the delco in their non uni-point version
http://www.partsamerica.com/productdetail.aspx?mfrcode=nie&mfrpartnumber=dr8hv&parttype=199&ptset=a
Yep, those are the points we've got. Tested the original coil and it couldn't jump a 1/8" gap. We installed the accel coil and got it to easily jump a 1/2" gap. Reinstalled the points, condenser, and the new coil and are getting much stronger spark at the plugs. Installed new plugs, old ones were pretty fouled. Verified timing w/o valve covers on and it matched with the timing Mark on balancer and location of piston. However, it still won't fire. Point are opening and closing like they should and air gap is at 0.016". Still using a dedicated 12v jumped wire straight from battery. Points have 0.4 ohm resistance. Are their any checks to make sure the condenser is correct? We've got bwd's g111 condenser, which comes up as one for this engine on the partsamerica website listed above.
Ok,
you know for sure that you have good spark. 1/2 " is good so I would think the condenser is fine.
Assuming the spark is occurring at the correct time(you assure us it is), all you need is fuel. Add fuel perhaps 2 table spoons in the carb. Open the throttle a crack and crank it. It will fire if your timing is correct +/- 20*. If it doesn't. :dita:
can you take a photo of one of the old plugs?? May give us some insight of fueling.
We're using champion rj12yc plugs. Think of the plug new and color everything below the threads black, then you'll know what they look like. We have to go pick up some new valve cover gaskets before we kick it over. The old ones were not really in re-usable form if you know what I mean.
They were matte black when they dried off. They were wet from fuel. I tried to clean them a few days ago with carb cleaner, but it didn't clean them up much. The electrodes weren't worn at all so I imagine the po replaced them but was unable to get the thing started and they just got fouled up with all the starting attempts.
When it had idled a little a few days ago, there was exhaust coming out of the tail pipes so I don't think the exhaust passages are blocked. When rotating the crank, all the lifters on the 2,4,6,8 cyl side seemed to move when they should. For the sake of letting you all know what we do (or don't) I tested compression on the even side cylinders and got 120psi on all of them.
Unfortunately, the fuel is less than a week old. We'll try dumping raw fuel down the carb when we put the gaskets back on tomorrow. We've been using starting fluid (spray) before each try or two and giving the throttle arm a little bump to make sure the carb is putting gas into the runners. Are there any critical vaccuum lines that need to be connected? We've got most of them pulled and plugged (except the vaccuum adavance). When it was idling rough a couple days ago, we sprayed carb cleaner on the lines and the engine never surged at all so I don't think any of them are leaking.
Now we are getting somewhere!! Just to verify currently when you crank the engine with the cap & rotor on you can get it to jump a 1/2" gap at a spark plug wire? If so and it still won't start with clean plugs (and a prime shot or starting fluid) it is time to statically time it. Like many things there are different methods of doing such but here is one way to do it on a points type rig.
On the dist body make 2 marks, one directly below the #1 terminal and one directly below the #8 spark plug terminal. Rotate the engine till the timing Mark is between 10 btdc and tdc. Loosen the distributor hold down. Here is where it gets a little tricky to explain over the interwebs but I'll try my best. The rotor should be pointing to the general direction of the Mark you made for #8 or between #8 and #1. Rotate the distributor so that the rotor is pointing between the 2 marks and verify that the points are closed. Establish a 1/2" air gap between the coil wire and ground and connect the b+ jumper to the coil (+) terminal. Now slowly rotate the dist #8 Mark tword the rotor when the points open and a spark occurs stop. Lock the dist down, re-assemble and try starting.
If you can get the 1/2" spark from the coil wire but not at the plug wires then the spark is getting "lost" in the dist, and we need to go down the diagnosis path for that condition.
Don't worry about the vc being off, depending on what wt oil you are using, the ambient temp and general condition of your engine it can take 30 sec or more before oil is present in the rocker shaft and it starts splash around. Setting the vc on the head will limit the oil splatter if you want to run it for while.
If the coil is able to jump the 1/2" gap then the condenser is fine, the main difference between the straight and curved point condensers is the length of the wire. Mismatch them and you will either not be able to connect the wire to the points with the condenser bolted down or you will have ~2" extra wire.
Thanks eric, when we got the coil to fire a spark (we didn't test if a plug wire could jump a 1/2" gap...but we could), we actually did have the distributor in the engine. We just used jumper wires from the points to the neg side of coil to tell the coil when to release the voltage from the primary. What we didn't do was what you described when lining up the coil with the cap. I'm thinking we are losing spark around in the dizzy because when using a spark tester, we were getting the usual strong spark along with many smaller sparks on any given plug. I am thinking that means the spark is jumping to multiple different poles instead of just the one closest to the rotor. Maybe the points are staying open too long. Our distributor cam gear has pretty rounded lobes...should they be more distinct points like a bolt head or are they designed to be rounded off more. You can barely see what I mean in the pic of the rotor from before. I'll see if we can get a close up shot of the dizzy cam gear tomorrow.
What we didn't do was what you described when lining up the coil with the cap. .
That is called rotor phasing. If you have the correct points cap and rotor installed there is no reason to believe the phasing is off. But (always a but :gringrin: ) lets move to the next item in this post. First
I'm thinking we are losing spark around in the dizzy because when using a spark tester, we were getting the usual strong spark along with many smaller sparks on any given plug. I am thinking that means the spark is jumping to multiple different poles instead of just the one closest to the rotor. .
This can have 2 causes.
1) rotor phasing.
2) carbon tracking. Once you carbon screw up rotor phasing you will/can create small lines of carbon (conductive residue) in the cap that will conduct the spark around the cap from then on. Really only one fix for sure, a new cap. Might change the rotor also.
This is normal. The cam lobes should have a rounded tip not a sharp point. As long as the cam is not grooved where the follower rides you should be ok.
When you are prepared to go through a step by step rotor phasing regiment post up after you make sure the advance mechanism under the breaker plate is sound. All you need is a vom (preferably with a tone setting) and a marker to indicate the location of the # 8 plug wire tower of the cap on the dizzy body.
Everybody is trying to help you figure this thing out but I think you need to put all your prior beliefs behind you and follow some ones lead. You will find the problem so be patient
Well it finally fired tonight running the hot wire setup. It still isn't timed correctly and I think the gas tank I am running May need cleaned out again but it does run so that is a step in the right direction.
Getting it running smoothly is most definitely the next step, but I also need some help figuring out how to fix the lack of voltage in the ignition wire going to the coil. That is the only reason I was asking for a wiring diagram before to hopefully track down where the wire is shorting. All the wires in the wiring harness containing ignition wire to the coil are black so that makes it difficult to trace where things are going. I am assuming into the connector on the firewall near the brake booster heading in to the ignition, but I am not sure.
Exhaust fumes!!! The smell of progress!!!
