Mochamike
Spring of 09 I rebuilt my propane set up (all new gaskets on the regulator & mixer). I ditched the vacuum lockout in favor of electric ones located at each tank (so I don't have to switch tanks while wheeling).
Installed a new square bore base plate, which I got off ebay (old one was poorly modified). The new one has 1.75" primaries & secondaries, vs. 1.5" on the old one.
also installed a new hei dizzy (old was a $20 jy one, which worked ok, but I wanted new).
Only bought the dizzy because I'd already bought the base-plate from the same seller (got smoking deal too... $120 for both).
She fired right up & sounded way better (even before timing her).
Baseplates pre-rebuild/install...
Hoses & lockouts as the sit on my workbench (waiting for a few more fittings to arrive):
Finished product (still need to clean up the wiring & run 1-2 vacuum lines):
