Robert Kenney
Super Moderator
Mark,
I have no idea what amount of temp drop one could expect.
The biggest factor will be the temp and volume of the water flowing through it. If you can plumb coolant from the pump out and back into the ts housing before the ts you'll have a good chance of cooling significantly. I would plan on seeing a oil temp to coolant delta of 15*-20* f.
