Robert,
Here are some cheery numbers! This morning I was playing with the PerfExpert dyno app. Found a flat, country road with a decent, level, smooth surface, and made some runs. The thing with the app is that one enters a lot of parameters, and via GPS it adds in local meteorologic data, and then one does a very soft launch in 1st gear, just enough to get rolling and then shift into 2nd, still under 2,000 rpm (I don't have a tac but am sure I was under), then you punch it and run it up to redline, then coast. With my gearing and tire size I calculated that to be around 4,000 rpm @ 40 mph. We know how accurate the speedos are on these things. So when I hit 40 the engine was screaming, I let up and coasted. Here are the rough numbers; I say rough because I still need to find a local public scale to zero in my running weight with a full tank of gas. I am using earlier numbers that I'm sure are reasonably close. This is with stock ignition and settings, full smog gear (EGR disabled) and cat. On one of the runs I hit over 4,600 rpm before letting up! Good thing I replaced all the springs (Jeff had a stash of OEM springs) when I did the rebuild! Float would be a very bad thing.
Flywheel: 100 hp @ 4,051 rpm; 165 ft-lbs torque @ 2,024 rpm
Rear Wheel: 85 hp @ 4,051 rpm; 140 ft-lbs. @ 2,024 rpm
Published data is 103 hp @ 4,000 rpm / 176 ft-lbs torque @ 2,000 rpm. Assuming that is a fresh engine with an ideal "tune", on a dyno, with accessories, that isn't too bad!
Observations: I liked the Dynolicious app but never got a chance to really use it properly, and in any case it is now defunct. The runs I made with it were at an elevation around 1,200 feet, and getting clean runs was dicey because of the iPhone mount. Lot of vibration and false starts. This is easier, and I taped the iPhone to the surface of the transmission cover, right behind the shift lever. No vibration there! Today is humid (when isn't Houston...) and elevation is around 100 feet. Next step is to verify the weights and make and average a number of runs to establish a decent baseline. A concern I have is after I get the turbo installed. Power will be measured with whatever boost I am generating half-way through the pull in 2nd gear. As we know, boost is a funny animal and depends on gearing and load. The app has a "timed run" option for generating numbers, and I'll have to delve into that to see how it works. If it is timed over a known distance, then I should be able to generate more realistic numbers once I pull boost in 3rd or 4th. From previous experience, that is when the engine began to sing!
