Provience
So I was able recently to get my 1976 terra w/345 t-19 unilight dist and mallory coil to run and idle smooth with the freshly rebuilt 2210 carb, thanks in large part to all your help. While checking for leaks, I opened the throttle to add some pressure and managed to create a loud lifter rattle on the passanger side
. Shut the motor down and hooked up a mechanical oil pressure gauge, as the electric one must have taken a shit, and fired it up just long enough to verify zero oil pressure.
Figured we would pull the dist and run the oil pump off the drill to see what we could see and that is where the fun started. When we pulled the dist out, the oil pump drive on the end of the shaft had twisted and snapped flush with the top of the oil pump
turns out that to remove the oil pump on a stock height Scout II, it is possible to remove the steering linkage and have enough space to finangle out the pump seperate from the pick-up tube.
When the pump was out and in my hands, it would not rotate at all. After dissasembly, the gears had made contact with the plate that sits below them and managed to wear up enough metal to cause the hole thing to seize together, thus snapping my dist shaft.
Purchased the oil pump rebuild kit from Jeff
And cut out the old gears
And installed the new ones. The rebuild kit states that you need .003" of clearance min. So I used both supplied appropriate gaskets to get that.
Iirc, my engine rebuild kit only had 1 gasket and it must not have given me enough clearance.
For the plate, I used various grits of sand paper, finishing with steel wool, to remove the ridges created, though contact marks still remain in the plate.
Question: will this cause the same failure in the future? The rebuild kit did not have a new plate so I am hoping that it will be okay.
With everything re-installed, I am getting ~25 psi at "very slow drill speed"
And ~45 psi at "fast drill speed"
Do these numbers sound good running 10-30w oil? It seems like it should be good to me, but asking doesn't usually hurt anything.
I have at least another week while I wait for mallory to send out another shaft, so there is plenty of time to pull it apart and play around some more if need be.
. Shut the motor down and hooked up a mechanical oil pressure gauge, as the electric one must have taken a shit, and fired it up just long enough to verify zero oil pressure. Figured we would pull the dist and run the oil pump off the drill to see what we could see and that is where the fun started. When we pulled the dist out, the oil pump drive on the end of the shaft had twisted and snapped flush with the top of the oil pump
