looks like the IH Parts America store is out of the correct rotor. Will this one work? http://www.rockauto.com/en/catalog/...id+v8,1494453,ignition,distributor+rotor,7136
The blue one?
went and cleaned off the dampner and all I can see for marks is one line is there supposed to be degree markers on these or do you need a special timing light to time these?
what a tease.;-] On an old loadstar it probably looks like a lump under the grease and dirt.
May have to unbolt the shroud, an push it back against the engine, then lay on the fender, snake your arm down in there an get it wiped off. This have the " batwing hood " ? Maybe even snake a pressure washer wand, down there and hit it a few times ?
Timing the engine:
Open hood.
Attach timing light to battery + & - posts and attach to plug wire #8.
Start engine and allow to warm up to normal operating temp.
Adjust point dwell/gap to spec.
Adjust idle speed to spec.
Adjust timing with timing light, loosen distributor hold down bolt to adjust timing.
Rotate dizzy until timing is in spec, then tighten bolt.
Remove timing light.
Close hood.
ok but what are the specs? Thats what i need to know. Im at 6300 ft elevation i no that has alot to do with how to time this engine
