ldo_marlin
Does any one run a 195f thermostat? I bring this up as it was the solution for my overheating problem on my 85 suburban with a warmed 355, manual trans, high flow 180f thermostat, new radiator, new hd fan clutch, new hd waterpump. It would get up to 240f+ going up a mild hill towing a fairly light load, ac off. Not towing, it will run 210f on the highway on a warm day.
Then I remembered an argument about water moving too fast through the radiator will not efficiently cool down before being pumped back through the engine. I decided to change to a 195f t-stat (not high flow). That solved the overheating problem. Under the same condition, it will get up to 220f only if the engine revs up past 4k. Engine rpm at 3500 it will stay around 210f. This is due to the fan clutch disengaging at high rpm. In addition, the motor runs better on the 195f t-stat. This is probably due to the head design for less smog. But I've had people tell me that their motors run better with 195f t-stats. IH owners included.
this is no show Scout that's for sure, it's my trail rig. So sheet metal trimiming is not an issue. I should have it ready by the weekend for some testing.
anyway I will hook up with him and see these numbers for myself. Stay tuned.
