Craig,
you seem to be cross posting about your "overheating problem" all over this forum and others. Let me point out a few things about your set up -
1- your engine is fairly new(rebuilt) and I have found thru the many years that I have worked on/repaired/overhauled these engines that these IH engines have a tendency to run warm when new(rebuilt) until the engine breaks in(15,000-20,000 miles ought to do it). [Craig]
Warm would be nice, but it wants to boil over and I have to pull over and let it cool down
2- you are driving a highly modified Scout with fairly large tires(37's to recall) with what I would consider tall gearing(4.56's if again I recall correctly) in the midst of a hot sacramento summer. [Craig] Correct
3- your Scout with its modifications weighs I'm sure at least 6000#'s(educated guess) which is at least 1200 plus pounds over stock. [Craig] I can have it weighed if that helps
4- you are running a cooling fan set up that was not factory on these rigs. [Craig] I’ve tried 2 different factory fans and now have a dodge viper electric fan on there, not for fun that’s for sure, just trying to get the Scout to not overheat. At this point it’s the best thing as I can pull over the let it cool down with the hood open and running at an idle. With the stock fan setup I could only turn the engine off and wait for it to cool down.5- you are running a fuel injection system that May not be 100% properly tuned. [Craig] I have made several adjustments to get it running good, even bill says all my data looks good. Do you have any recommendations?
If your engine was truly overheating it would be blowing coolant out of the overflow. [Craig] I don't like to get to that point, but it has happened. It boiled over at hollister, outside temps were in the 70's. At this point I suspected a bad fan clutch, and switch to a fan that’s bolted directly to the water pump. I normally stop and let it cool down before it gets that far. Once the temp gets to 210 I watch it very close. 225 is my upper limit before I pull over.
I know from day one you were not happy with the cleaning job the engine machine shop performed on your cylinder heads. You brought in to me a core which was in poor shape. [Craig] You never said anything, I have more heads, does the inside of the engine look the same? the engine shop did the best job that they could with what chemicals they can use to clean your heads/block. [Craig] Agree if you are not satisfied with the service we performed on your engine than bring it back to us. I will for no charge tear your engine back down, have your block recleaned along with your cylinder heads, and reassemble all under warranty as long as this fix's your problem. If this doesn't fix your problem than I would want compensation for my wasted time. So if you are absolutely confident that by recleaning your heads/block that it will fix your "overheating problem" by having the heads recleaned than bring it back and I will do what any honorable shop would do and thats make sure that each and every one of my customers is 100% satisfied.
