Data logging run
Good to hear.
I edited the old bins out of this thread due to a problem in the file.
It caused bad surging at rpm.
I did not want people downloading it and trying to use it!!
Did you happen to save the blm table?
There was a lot of idling in that log.
Looked like there was a few Rich areas but will need the blm's to see the avg.
I checked one of the other logs and the map was about 50 at idle.
It is definately high.
May need to be looking for some vacuum leaks.
  • 20070428_172221_LOG.xls
Mike - good that you found the problem. I am holding off burning your backup chip 'til you get log data. Gives you a damm good reason to take your rig out and beat it again :icon_idea:
make sure you reset the ECM and save the blm table.
