Robert Kenney
Super Moderator
Your pin is 3.5"long? I May have one I can measure for reference of measure the stick out on my 65'. I you think that would help.
your pin is 3.5"long? I May have one I can measure for reference of measure the stick out on my 65'. I you think that would help.
2 3/4" would certainly work, though it could be longer and still work too. I'm a little unclear on what happens when it's too long. I think from other threads of yours I've read, you are saying that there really is nothing to stop the fork from going right up into the clutch pp body and getting shredded if the throw is too long? If so, that's just awful design! Ideally then, what stops the travel? Does the pedal stop up against the firewall, or the slave or master reach full travel? The slave only has a little piece of wire holding its piston in if I'm looking at it right...
With the fatter fork it looks like the fork hitting the bellhousing could be a hard limit, so ideally that would bottom out before the fork hit the clutch housing?
I want to make sure I go about the tuning process properly.
I was referring to the release position like when your foot is off of the pedal. As the clutch disk wears(looses thickness) the pp fingers reach further toward the through out bearing. Thus the slave will need to be able to retract further.
If it went away I would not worry about it.oh okay. That makes sense.
I trimmed my pin down a little bit and everything seems to be functioning well now. There was a little bit of shimmy and noise (not much, but some) when the to just touched the clutch, like with the weight of my foot on the pedal. It seems to have gone away after the test drive though. Should I worry?
Also, the little spring I have on there doesn't always seem to draw back the fork to the stop. I can easily bring it back by hand, so I think maybe I just need a little stronger spring. It makes me wonder though, should there be any grease at all on the tranny snout for the to to ride on? I think I asked this when I was assembling everything and the answer was no, but it seems odd to have no lube on a friction surface like that. I think I put a film of rem oil on there but nothing else.
Anyway, it seems I dodged a bullet not having to pull the clutch or anything. It's seems to be working perfectly now.now back to dialing in the engine.
well, that noise I was trying to explain above is actually not going away. Maybe I imagined that it did, I don't know. I have a noise and slight vibration when I'm at partial clutch. Full clutch and it goes away. It sounds sort of like the sound when they are making you a duplicate key, but not so high pitched. A periodic scraping sound. My only guess is that the clutch fingers are not all contacting at the same time? Or maybe its normal... I have no top plus numerous gaping holes into the engine compartment. I hear everything. What do you guys think?
Don't obsess over stuff like that, these vehicles are one step removed from an IH manure spreader, they are not "finely crafted" examples of motor vehicle engineering!!
