harrywt
This is part of my rebuild but I created a new thread because I wanted to get more attention on this particular issue.
I borrowed this picture from the parts listing here at IHPA, I bought my clutch here. I thought I took a picture of my clutch after dropping the tranny but must be in my virtual memory.
Anyway, we are focusing on the three screws on the end of the actuator arms of the clutch. Red arrow in this picture
I noticed that all three screws are worn down and galled on top. The clutch has only been in service for a year. I believe that the throwout bearing always had contact with the screws even with foot off of the clutch pedal.
One of the screws spun and stripped its threads
The hole in the clutch arm is stripped also but the screw was still in place so the whole is not too cammed out.
My guess is that I could put a similar screw in there with a backing nut and it would be held in the proper place.
First of all I need a sanity check, is this a stupid thing to do?
If it is, can I simply replace the actuator arm of the clutch? Since the clutch is only a year old I think replacement is too severe a solution. Especially since the shipping charge to korea might be a bit high....
Please share your wisdom!
