Michael Mayben
An "expansion"-type cam bearing tool set does not use a "disc" as commonly found in bushing driver sets. The driver adapter for each cam bearing in a full set must be capable of being adjusted to exactly fit the id of the particular bearing being installed. In the case of the ihc sv engines which use five cam bearings, then the correct driver head must accommodate a broad range. However, in all the various cam bearing tools I've used over the years, the same head is used for all cam bearing positions.
Older driver heads used two, three, or four "o" rings to support the bearing and center it in the head/mandrel, the rubber rings can't cause any bearing surface damage if installed correctly.
Most of the newer cam bearing tools have a urethane "band" that completely surrounds the expansion die segments, then the bearing is slid over the band and the expansion nut snugged up by hand in preparation for setting the tool into position in the block.
The expansion heads/mandrels are numbered 1 thru 5. All ihc I-4/sv cam bearings are installed using the #3 expansion head/mandrel.
