Big Metal Pieces in Oil Pan
In that case I’ll replace my battery charge gauge. That one isn’t connected anyways. My OEM OP gauge is reading 75% missing one or more can shaft bearing with the oil level right where it should be. I hope it isn’t accurate haha
Hopefully I can find these square head plugs
No, that doesn't sound accurate. You'll see them when you get under there. They take a small open end wrench, or an 8 point socket...has to be 8 point only to fit a square head. What most people do with those after market gauges is just mount them under the dash somewhere.
I didn’t want to admit it, but the rust in the fuel tank was the cause of all my issues.
I spent so long cleaning that tank, I think my pride got in the way.
You were right originally, thanks, @Scoutboy74 !
