Thanks for the pics. What I see in that batch, carb-wise looks decent. What happens if you remove that screw which is limiting float travel? I've never seen that there before. The float arm has to be able to contact the needle to shut off fuel flow at some point. Otherwise the bowl will just overfill with fuel. It also looks like you might be missing a plastic retainer for the float arm spring. I'm going off memory from the last time I was in one of these carbs, which has been years, but that doesn't look right to me. Did you remove the brass sight plug from the side of the fuel bowl to observe fuel level while the engine was at curb idle and vehicle parked on a level surface? That is the proper method for viewing the level. Then if a needle adustment needs to be made in either direction, you shut off the engine and make the adjustment. Lather, rinse, repeat until the level is just at the very bottom of the plug hole with the slightest weep or dribble, but definitely not a gusher.
Your distributor vacuum advance is sourced from a manifold location. If you can get a secure hose attachment to the metal tube, you could use that for your vacuum gauge readout.
