71mtnscout
Took both doors apart and pulled the windows out and did 1" velcro hook on the front track, the rear track was still intact so I lubed it and left it alone. I will never put door window felts on beater so I used the cloth side of the velcro on the outer door sill to stop the widow frame to door rattle when the windows are down. Added some strategic rubber pads to the glove box door to stop that rattle, all in all it's getting quieter while driving...still can't hear a radio at highway speeds, but below 55 mph you can.
The engine has always been "piston slap" noisy for as long as I've had it but it runs great and has good compression and oil pressure. So while out on a test drive today I was climbing this hill in third and when I punched it pinged. When I got home I decided to check timing.....I guess I never checked it when I got it. It was timed at 12* btdc, what a dolt I am, I reset the timing to 0 and went for a drive...what a difference!!! The engine is sooo much quieter and has more pull on the top end too, can't believe I didn't check it!
the rattles are slowly being resolved and it's driving better and better, its becoming a solid driver...now if I can stop the body rattles...
