The missing bolt will most likely be discovered lodged in between the pinion bearings along with a bunch of those missing teeth.Upon further inspection. Looks like all of the hex "cap" bolts have walked out. Missing one entirely. Seems it got munched up along with all the teeth. Sent ARB an email and hoping that their warranty will cover it. If not, this got way more expensive
Yeah I wasn't going to attempt doing gears outside in the snow. Also a good time to replace some spring bushingsYou did make it easier taking it out of the rig at least. I always leave it under the rig. My front 60 has to come apart to replace the Quad seals on the ARB and the axle shafts need to be swapped for new chromo's.
They are waterproof!Are they waterproof? Scouts love to leak water there, I'd be concerned about shorts.
