Scoutboy74
Moderator
I've been looking through Tom Hand's online guide to the TF727 during this time, and there just isn't any one thing jumping out at me that could be causing the symptoms you've noted, other than incorrect fluid pressure. Sure, there could be a problem with either of your clutch packs. If there is, you won't be doing anything about it while the trans is attached to the engine. When you had the VB halves apart, did you look them over carefully for cracks or damage in the passageways? Tell me more about this kit you installed. What brand is it? What modifications were required? Please be specific.
One little thing can really bite you in the backside sometimes. Great learning experience for you, though. Now, if you can just keep those lads from shock-loading the damn thing. I imagine they've learned they're lesson on that count. I did the same thing once in my high school hot rod, trying to impress a sweet Betty in a Hoopdee Accord stopped in the next lane. 351 Cleveland mated to a C-6 auto smoked the tires up real purdy once the light went green...then clank, clank, clank and huge clouds of white steam billowing out the seams of the hood. Miraculously, I didn't damage any of the drive train, but the fan blade sure ate the hell out of the oversized radiator I'd shoe-horned in. Betty Boop was very impressed as she drove off without so much as a backwards glance, never to be seen again. Come to find out, they really aren't that impressed by displays of vehicular abuse. Who knew? Some alcohol may have been involved as well. Not one of my prouder moments. Feel free to pass that one along to the boys if you like.
