Here's a pic of Mark's buggy.
Mark, did you receive the carb today?
As for an electric fan, I've got no real world experience with 'em on my own stuff. But the big deal on 'em is a functional shroud that completely encloses the air-off side of the radiator with no non-shrouded portion of the radiator open.
I'm assuming you are currently running the oem truck radiator Mark?? If so, those are massive for those engine setup when used with the oem fan system. The actual use of a a thermo-control fan clutch has nothing to do with cooling system operation other than to cut down on engine-related noise at speed. And since you have no effective vehicle sheetmetal in front of the radiator, the noise thing means nothing and you do actually see a bit more air once you are running above 15>20mph.
So setting up an electric fan in your case is certainly viable, I'd use the one with the greatest volume you can find that fits the picture. Those can actually suk down 40>50 amps of current though at speed so keep that in mind.
The electric setup on maranda's pink Scout mud rig in this pic does a wonderful job once it's purged of all air. The radiator/fan came to monte through one of their sponsors so he'll have to reveal the source! I can't find the pics I have of the setup on it but will update this thread when I do.
By the way, the overall physical size of the Scout II radiator is about 20% smaller than the fullsize radiator you are probably running.
