Monte Lauer
Active member
Looks good. What do you do about the e-brake? Line lock or forget about it?
looks good. What do you do about the e-brake? Line lock or forget about it?
nothing yet -- it is an automatic - that is what park is for :d
yep!
That rotor looks way better the drilling the Chevy rotors like I did. Course I'll go to great trouble to keep dodge parts off of my rigs.......![]()
does the id of those rotors fit snugly on the axle shoulder?
got to working on the tranny kickdown linkage -- I think I am going to toss it all out and get the lokar version...
There does not appear to be any keeper on the bottom of the linkage rod where it meets the tranny lever - and no provision for a keep. So I have my doubts if it has been working correctly the last few years.
got a ton done today. Got the inner knuckles welded back on - 'custom' axle shafts built - and one side completed.
Now for the pics:
measuring for the new caster angle:
Welded back toegther:
Getting ready to swap the Scout outer shafts for Chevy outer shafts:
Scout inners shafts with Chevy outer shafts:
Redrilled Scout II knuckles for Chevy spindles:
Chevy spindle and caliper bracket:
Ford hub and rotor with regualr locking hub:
chris what did you use for a template when you redrilled the knuckles? Did you bolt the spindle on using the top and bottem stud and then Mark the holes? And also, are you using the stock mc after doing the rear disk conversion?
This is a nice write up. Thanks.
don't ya luv shit that just works???
