I use sae 15w-40 weight in both my '79 Scout IH 345 I recently rebuilt and also in my old '79 Scout (250,000 mile) 345. Oil pressure is fine in both, although the older one uses a little oil over time. I used to live in Pennsylvania until 12 years ago and they were my daily drivers. Here in georgia I usually drive them mostly during warmer months, but they still get exercise all year from 30 to 90 degrees. So 15w-40 swepco or any quality brand that is good for solid lifter cams (similar to the old api class se) should be fine. Otherwise, I defer to the swepco agent in this forum.
Fyi: --I have the original '79 Scout owner's manuals and in the '79 owner's emissions manual it has a whole lot of choices of straight and multi viscosities for a whole range of air temperatures from -10f to +120f deg. Using from 5w-20 up to 20w-40 (with a service classification of se-cd, se, or cc).
--I also have the original '72 Scout owner's manual that says use sae 30 or sae 20w-40 for over 32deg. Air temp (with a service classification of sc or sd), and gives lower weights for lower temps.
