B&GScout
77 SSii, 345, 4x4, 3 spd, Edelbrock 1406 with 5.5 psi regulated fuel pressure supply. Carb has stock rods and jets. Note until recently engine ran fine with this carb set.
Gold Box with Holley electronic 3* curved point Dist plumbed to ported vac on carb (passenger side).
Carb is tuned, 20“ manifold vacuum, A/F mix happiest at 2 turns each based on vacuum and rpm readings, hot curb idle sitting at 675 RPM. Choke fine.
Plugs all clean. *Wires all well seated on both ends*
Base timing 8* (tried 10-12* and in doing so noticed the below timing light behavior. Read on).
Distributor cap looks healthy, clean, seats well. Rotor same. No noticeable wear on either. Bushing seems fine, no wiggle.
Just replaced bad vac advance and new one from IH Parts is working fine. Mech timing seems to be fine and fully functional. Total timing is >25* scale.
New and correct PVC Valve.
No detectable vac leaks.
Fuel filter is good.
Just filled gas tank with fresh non-ethanol. Didn’t just top-off the tank, it was low. And that existing, remaining gas was only bout a month old.
Engine starts fine, does not struggle. Easily starts when cold and hot, rain or shine. Rock solid engine temp while operating.
In earlier thread I inquired about use of Flamethrower coil, but I am still using existing coil which Ohms at 1.5, doesn’t get hot. There are a number of photos of my dist there in that thread. (See “77 Scout 345 Coil Upgrade to Pertronix“ (started thread on Feb 13, 2021).
Am sitting tight on coil change so as to limit introduction of too many variables. So the only changes made as of late are new the PVC, plug wires, and the faulty vac advance canister replaced.
OK, so all above is background info.
My Situation Now
Been chasing small miss, I’ll call them bobbles. Detectable at idle, a bit more pronounced when slightly accelerating in 2nd and 3rd gears. No backfiring, pinging or anything like that. Ditto on hard acceleration once at highway speeds 55 MPH+ no pinging, no bogging.
Not smelling any excess exhaust or rich fumes at any time. It’s just those darn bobbles.
Here’s what I am homed-in on at the moment: I noticed when checking timing (#8 cyl) my standard timing light was in sync with the bobbles — engine would barely stumble and light would as well. Hummm...At first thought maybe timing light not picking-up well around plug wire, light was fine. Now I am thinking.... And since I can hear bobbles on both sides of engine via dual exhaust sounds I checked all other cylinders. I see same bobble result on cylinders 1, 5, 4, 8. Other 4 cylinders don’t miss a beat. This is very consistent, not random. Its actually very rhythmic.
Behavior of timing light aligns with bobbles and indicates some sort of ignition miss.
Scratching head. Is it time to pull gold box along with the dist electronics and install Pertronix? Many wise warhorses haunting these forums report the gold box is either off or on, no in-between and doesn’t exhibit these sorts of bobbles. I do wonder about the electronic module inside the dist??
*Also need to advise I just replaced plug wires with 8mm set.* Verified proper wire location/firing order — I don’t have any wires mis-seated.
These are quality wires but are a universal set I had to terminate myself (dist end) using good crimping tool. Like to think I did good job there. But did I?
Note I was very thorough with terminations and I DID ohm all wires after I built them. All ohm’ed fine, very low. (Am gonna take another close look at wires, will swap a “good” one with a bobble one to see what happens via timing light behavior.)
Anyone ever run across these ignition/firing bobble symptoms? What is that timing light telling me?
Paul
My Situation Now
Paul
