Sorry for the delay in response. I've tried about every avenue I know to upload a video, or even a link, and it's proving to be a bigger pain than fixing this truck. I have a youtube account, but I rarely use it, because I'm just not into knowingly giving google any more information about me. And every time I log into any google based account I have, my computer does crap I don't like for days afterwards. And somehow even my photobucket links won't work. I'm guessing it's something to do with security issues on this site. And I'm totally ok with that. So I don't know if there will be a video here.
Recently I haven't a lot of time to mess with it, but here's what I did do. I verified that the fuel tank was clean inside and that the sock on the end of the pickup wasn't plugged. Since there was no sock,… so then I rigged up a gas can with a line straight to the carb. No fuel lines from the truck to worry about. No real change. Then I ran a jumper wire from the battery and essentially hot wired it, so there was nothing coming to the coil through the ignition switch or the truck wiring. No change.
it will start right up, but sometimes it runs like it's slightly flooded until it runs for about 30 seconds. Then it runs well. But if I drive it, or just power brake it, after about 10-15 seconds with a load it just starts dying out. I can then return to an idle, and it runs fine. And it will do that as many times as you want to sit there and try it. So since it comes and goes suddenly, I'm leaning towards an ignition problem.
About the only thing left that I can't verify is the ignition pickup in the distributor. And since there doesn't seem to be any shops around anymore that can diagnose vehicles without an obd2 system, god only knows if it's acting up or not. But since I'm looking to go GM TBI, I'm undecided as to what to replace it with. I have two Holley distributors that I could also convert to whatever. I'd like send off one of my holleys to get the GM small cap hei from the TBI setup grafted onto it. But after I get that back, I don't yet know how to wire that up to work with my carb until I get the efi ready to install. Seems that no matter what I do, I'm dropping about $150 on the distributor, so I don't want to do it more than once. Some research is in order.
