un obtainable head bolts/studs
1hc72
I will be getting ready to pull the heads of my 345 here in the next few weeks (and gathering parts to rebuild a 392) and need headbolts/studs. I can not seem to find them here or anywere on the web, can you tell me were I can locate a set? Or what ohter engine I can use to search for that will work on my tired old sv motors??? Thanks guys
On the 392 I dont have them. And on the 345 would like to have a replacment set incase I strip head or otherwise screw a bolt/stud up
Did anyone find the head bolts? The ones close to the exhaust side on mine rust has made the threads rather rough, and since I am putting new heads on I would prefer to replace the head bolts.
47 Dodge, look at ARP for the bolt by size. Measure what you have and look for a close match. Add hard washers for a bolt replacement that is a little long.
We are currently working on getting head bolt sets as well as stud kits. No time line at the moment, but hope to know more by end of the week.
Moin,
Ich bin der Jörg aus Deutschland und bin gerade dabei, meinen 1967er Trip mit dem SV 304 wieder aufzubauen.
Können Sie mir einer verraten, mit welchem Drehmoment die Kopfschrauben angezogen werden?
LG aus Deutschland
Hi Jörg. Here is your question translated to English:
"Good morning, I'm Jörg from Germany and I'm currently rebuilding my 1967 Travelall with the SV 304.
Can you tell me what torque the head bolts are tightened to?"
What follows will need to be translated to German.
Head bolts need to be torqued in a pattern beginning in the center and working outward, while alternating between top and bottom rows as illustrated below.
9 - 3 - 1 - 6 - 8
7 - 5 - 2 - 4 - 10
Final head bolt torque is between 90 and 100 foot pounds, (122-135 NM), but this should be done in two or more increments, following the above bolt sequence each time.
Hallo scoutboy74
Danke für die schnelle Antwort.
Hallo Jörg. Hier ist deine Frage ins Englische übersetzt:
„Guten Morgen, ich bin der Jörg aus Deutschland und baue derzeit meinen 1967er Travelall mit dem SV 304 um.
Können Sie mir sagen, mit welchem Drehmoment die Kopfschrauben angezogen werden?"
Das Folgende muss ins Deutsche übersetzt werden.
Das Anziehen der Kopfschrauben muss in einem Muster erfolgen, das in der Mitte beginnt und sich nach außen vorarbeitet, wobei zwischen der oberen und der unteren Reihe abgewechselt werden muss, wie unten dargestellt.
9 - 3 - 1 - 6 - 8
7 - 5 - 2 - 4 - 10
Das endgültige Drehmoment der Kopfschraube liegt zwischen 90 und 100 Fuß-Pfund (122–135 NM). Dies sollte jedoch in zwei oder mehr Schritten erfolgen und jedes Mal die obige Schraubenreihenfolge eingehalten werden.
Hallo Scoutboy 74. Danke für die schnelle Antwort. Leider spreche ich kein Englisch, zum Glück kann mein Telefon die englische Website automatisch ins Deutsche übersetzen. 😃
You're welcome. Thankfully modern technology is able to help us bridge this language barrier quickly and easily. I responded to your introduction post as well. Hopefully no vital information will get lost in translation.
