Michael Mayben
I have been driving the Scout around town all day and have found that with every start, it has taken longer and longer to start. Lot's of pumping is required.
Any suggestions?
Too good to last huh??
If you have to "pump" the loud pedal, that indicates a fuel issue.
I watched your accel pump circuit actuate and it acted as it should. That means by pumping the pedal, each time it squirts additional liquid fuel right down the carb throats and creates a "flood". The only way to clear a "flood" is to push and hold the pedal wide open until the engine starts. Then don't pump it any more!
I'm thinking you May now need to "re-learn" your starting procedure. Remember, yore carb is equipped with the "hot air" choke system.
When full cold, if the choke system is working properly, then give it one rapid pedal push to "set" the choke and squirt into the throats. Then take yore foot away from the pedal and do not "pump" at all. It should go right to fast idle, it did that here though you May not have been aware at the time since you were snakebit!
When "hot" (say after sitting 15 minutes at the schoolhouse), again...one pedal push and then crank.
I'm not saying ya don't have carb issues now...remember we talked a bit about "e10" and it's negative effects on the overall fuel system? And the fact that your rig has set over the last several months due to the drivability issues has made the carb a prime candidate for e10 attack! Iirc you told me the carb was rebuilt quite awhile ago, typical service life on this crap we have for gasoline now is about two years if the rig is used consistently, much less if allowed to sit for long periods of inactivity.
So...try the "new" starting technique and then report back. It May not be perfect, but is part of figgerin' out what's going on! Don't rule out another work session involving a carb build...ya saw the pile of near identical 2300 carbs I have here, they all have similar issues...rotten fuel/e10!
