gulfdawg
I had the transmission rebuilt in my Scout last year. Ever since then there would be a "ting" noise right when I put it into gear or as soon as there was a load put on it, like taking off from a stop. It would do it once then nothing until recently. Now when I am driving, and not all the time, there is a ticking when the engine is under load. I can let off the throttle and it goes away. The ticking is rpm related, sounds like maybe a loose convertor bolt hitting or something of that sorts. I pulled the dust cover. All bolts are tight. There is no evidence, metal, of anything rubbing or hitting in the convertor area. I pulled the oil filter and cut it open looking for metal, none. I checked the fan it is not hitting anything. Any help would be much appreciated. I am not sure where to go next. Thanks in advance. Justin
