Course the above requires a pretty radical amount of welding done on the crankshaft. If a fella had a good 196 crank he wanted to use, the amount of welding could be reduced a bit since the rod journals wouldnt need to be built up, just narrowed.
If you want to totally avoid welding on the crank, seems like you've either got to get custom rods or else use a 196 crank and 152 rods, then a) get custom pistons made up with the IH pin size or else b) bush the IH rods down to something like the silvolite 1266 or 1278 depending on your deck height.
and put off discussing it with the balancer. Finally spoke with him about what I had done and did he think that my getting all the assemblies to within less than 0.5 grams of each other was close enough (plus I cc'd the pockets to verify they were at 14 cc). He had a good laugh over that one.
I couldn't see anyone else having the fun!! I'll yank the 152 out and drop the new and hopefully improved air pump in. I go to camarillo quite often and it'll be making the trip many times this summer if I get it done in time. Should be a good proving ground with all of the hills. Pleanty of time to lean on it.
