Hello,
I am not sure if I should have put this under the 23xx thread or if it was ok for me to start a new thread but here it is.
Let me start this by saying I am mechanically challenged. The point of me rebuilding my engine and doing all this stuff is to learn so that is what I am trying to do. If I seem dumb that is because I am=)
onto the carb:
the engine is a 266 just rebuilt (new pistons, cam, valve grind, ect, ect.
It has a dui dist with live wires that is brand new
all the electrical seems to be in order, we are getting 12v to the dist.
Now here is where it gets fun. The carb I think is missing some parts. When I bought the truck this carb was on and the guy said it was pretty new just was missing the throttle spring.
When the truck starts up it idles fine, but whenever you give it some gas it will bog down and die. Now the exhuast is not hooked up right now its just going through the manifolds. And we have not broken in the engine, and the radiator is not hooked up so that very well could be the problem but I wanted to get the carb as dailed in as possible before the radiator shows up so that hopefully I can get it on the road shortly after the rad gets here.
So here are the pics
front:
Back:
Right side:
Left side:
And top down:
I have no idea what the jets are, I am at about 2800 feet for what its worth.
Now am I missing any parts of the throttle assembly?
This is my vacume advance right? Is that the secondary fuel air mixture screw below it? There is one on each side?
What is that threaded inlet to the left of the choke?
Anyway thanks for look and I appreciate any and all help.
Thanks,
tren
onto the carb:
front:
Back:
Right side:
Left side:
And top down:
Thanks,
tren
