71mtnscout
As you all know I picked up a 64 s80 that my wife affectionately named "billy goat" due to the etching thats on the drivers wing window. This was ment to be my dd, but ruthie fell in love with it (I guess thats a good thing) and claimed it for her own. That story can be found here.
http://www.forums.IHPartsAmerica.com/readers-rides/4058-mtnscout-80-a.html
I picked up a 62 s80 p/u for me, but it needs alot of work to get it up to dd status, so I will have to get the goat in shape before winter sets in, so at least one Scout is in dd trim.
With the help of michael and his carb and 4cyl guru status, I managed to get the little 4 banger to run the way its sposed to. Today I tackled the engine compartment wiring mess, to see if I could get the systems working the way there sposed to. I completely removed the front harness and repaired the wiring to factory specs. Then I turned to the "no charge" problem that I found after having to push it home the other day, due to a dead battery. Searched it down to a non functioning regulator, that hasent worked for a long time. I removed the gauges that were installed in place of the factory temp/fuel pod. I left the oil and temp gauge working and will install them under dash so that I know wht is really going on with the engine, but wanted the origanal look of the dash intact and working.
Got it all together, broke the glass to he gauge cluster, installed it back to origanal, then fried the cvr in the temp gauge. Think I didnt have a good ground.
Waiting on a set of gauges that I bought from ebay and see if I can get some stuff to work. The fuel gauge never even moved, so I have some more work to do to find out why.
