Vinograd21
Hello, I have a 1974 scout II project that was originally a 258 straight six with a T-15 3 speed. I have completely disassembled the scout and started rebuilding it. However, I did swap a v8 304 and with it a T-19 from a 1978 Scout II. While trying to fit the T-19 in, I noticed the transmission’s mounting did not align with the crossmember/transmission mount, and that it sat 1”-2” farther back. Thinking I needed to put the “Z” plating on, I noticed the transmission looked like it was sitting way too high as I jacked it up to fit the Z plating on my transmission mount, so then I started questioning it. I began researching forums online about t-18 swaps for t-19’s on early scout II’s, and read that the t-19 should align with the rubber mount without needing the “Z” plate. So what’s the deal? Is the bracket location that holds the trans crossmember on the frame welded differently from the scouts that were built with V8’s or that had t-19’s in them since mine was originally a straight six and an early scout model? Did the later scouts with T-19’s have a different transmission crossmembers? I know it’s not the the v8 engine mount brackets I welded on, as I was able to get correct and accurate measurements to place them in the frame. Any help would be very appreciated.
