I have a 72 Scout II, 345, 4x4 with 727 tranny. I have been reviving it after a 14 year sit in a barn. Replaced all hoses, fuel line, fuel tank, new plugs, wires, dizzy cap, added pertonix, rewired bumper to bumper. Had the carb rebuilt by carbs unlimited. New exhaust and had carbs unlimited rejet carb, set timing and recurve dizzy. Rolled it out for the first time and it ran great. Quite, smooth and I saw an improvement from 6.7 mpg to 9.33 mpg. Ran about 80 miles over a mountain pass, rolled around offroad and again, ran great. Coming back over the pass about 60 mph, 3000 rpm into a head wind and maybe 3% grade, the engine started knocking horribly loud, pulled over to check. The knock was driver side, I checked oil levels, perfect, pull oil filler cap, oil visible. Set a bit, then started to nurse it home, maybe 50 mph and 2500 rpm. Knock disappeared. Drove another 70 miles, never to be heard again.
Any thoughts of the cause, is there a hidden issue waiting to blow? Would a strong headwind and grade cause a drop in oil movement? 10w30 full synthetic oil being used with wix filter.
Just picked up oil pressure gauge but haven't installed so I don't know my oil pressure.
Any help would be great.
