Robert Kenney
Super Moderator
.050 will just about center up the plunger. No matter, preload will have a range. You need to determine where you are right now. Between .020 and .100 is ok. Less then .025 will be ok but not in the sweet spot.
Measure anyway you like. But you will need to know where the valve events are to check preload properly. I do one cylinder at a time removing the pr's after.
If you ever need to adjust/measure your valves or set lifter preload on an engine with adjustable valve train. This technique makes absolute sure the valve you are dealing with is on the right part of the lobe/heal.
Remember e.o.I.c. Exhaust open intake closed
on a given cylinder.
When the exhaust is just open about .150 (1/3) measure/adjust the intake valve.
When the Intake is almost closed about .15 from seated measure/adjust the exhaust.
If eoic is a bit involved. On a small hydraulic cam with less than 270* advertised duration placing the cylinder on tdc compression stroke is fine. Do both valves on that cylinder.
