GaryOR
1978 Scout II, rebuilt over the past 4 years and just very recently became a driver. Intermittent starting problems, as if the battery is weak. Usually can be started with a jump.
Starter and battery replaced since onset of problem.
I think I have a battery drain, slow while sitting, quickly increased to the point of preventing the battery from having enough juice/current to turn over the motor when turning the key. Sometimes turns very slowly, sometimes not at all.
Battery has only 11.75 volts sitting last night. 10 hours later, measures 11.66 volts.
When turn key to run position, voltage drops to 11.4. When turn to starting position, voltage drops into the 6 range.
I think one of the wires in the ignition/starter system May be shorting to ground, but not sure where to look or how to isolate. Any suggestions?
Also, solenoid has r and s posts. What is the significance of the marks? Replacement starter was reconnected the same, assuming my son did it correctly.
