overdrivesteve
Hello everyone,
well, it finally arrived yesterday, from alaska. I've been waiting about 2 months, and now I hardly know where to start. But waiting did give me the time to study up on this truck, and start making plans for all the "enhancements" I wanted to do.
But now that it's finally in my possession, the work it needs just to become a dependable daily driver is daunting, and my knowledge, especially in regards to the engine, seems so inadequate. My only experience has been in restoring old Chevy trucks. So because I don't know where to post all the many questions I have, and I have a lot, I'm putting them all here. Otherwise I'd be posting all over the forum and I'm sure people would get tired of seeing my name everywhere.
Never before in my life (except when I inspected and test drove this truck two months ago) have I ever seen an IH truck, nor ever lifted the hood or sat inside one before. It's like discovering a whole new little slice of the truck world.
So here's my first set of questions.
I was told the truck would be delivered on a trailer. But instead it was delivered by dolly tow - where the rear wheels were in contact with the road all the time from alaska. And he did not disconnect the rear drive shaft, but only put the trans in neutral. Does that mean the transfer case and transmission are now toast? Perhaps I'm just being overly sensitive now that the honeymoon is over, but it does seem to have drivetrain vibration I did not notice when I test-drove it two months ago. I know some vehicles should not be towed that way, but I don’t know about IH trucks.
Next question. I've looked everywhere and I cannot find where the temperature gauge sensor is on this engine. I cannot find any wire for it either. In your opinion, where is the best place to put the temperature gauge sensor? Could it be the temp gauge is not hooked up? Possibly, except the temp gauge goes to and stays at the 1/4 Mark all the time the engine is running.
Or perhaps I just discovered the secret to never over heating - apply power to the gauge with no sensor connection.
In your opinion does the last picture show the best location and proper type of oil pressure sensor I need for my type of oil gauge? It also just stays at the 1/4 Mark when the engine is running. The second half of this video shows the unusual type of gauges I have: http://www.youtube.com/watch?v=13y1fd3d3gc
Final opening question - how do I open the glove box door? Is there some trick to it? The button is pushed all the way in. I think I May need to break through from under it. The po told me he has never opened it, and I don't want to force it with a screwdriver by bending the door out more than it already is.
So here's a couple pics of my new truck. I'm including a couple of the engine compartment too, because in my next post I'm going to start asking a lot of questions about things that don't look right to me in the engine compartment, such as where’s the crankcase breather in an IH, or is it normal to have one of the heater hoses go through the fender in an old IH, or why is there less than 2 inches of clearance between the tie rod and oil pan drain bolt and what if you hit a big bump that compresses the suspension more than 2 inches, etc. Etc.
So stay tuned for the laughs.
And thank you for your help.
Steve
p.s. Truck specs: a 1962, 3/4 ton crew cab pick-up truck. The plate says model c120 4x4 serial no sb291252b with a wb 140 with net hp of 180 hp @ 4400 rpm and gross hp of 193.1 hp @4400 rpm with a max gvw of 7000. But I was told the truck is an earlier model, such as a 60 or 61 but it is registered as a 63. The engine is stamped v305 453863 but I was told it was from a large, old military vehicle. The truck in the second half of this youtube video, inside and out, is exactly what my truck would look like if it had no rust, and except mine is a 4x4:
Steve
