Have a sii with a 345 with stock gauges and a 21 circuit ez wiring harness. I also just got a smaller pulley put on the 63amp alt, don't remember the diameter but only slightly smaller.
So the Scout had been running a little Rich but smooth otherwise until the battery died cause the alt was not wired correctly, which is fixed now. When I started it up after the alt fix it has been running a little rough and now has alot of white exhaust coming out. It does not smell like oil but does smell Rich. Is this just a carb tuning issue or is there something else going on?
Also, the stock amp gauge now reads as if it is charging. I have never seen the gauge move from dead center. Does this just mean the battery was not fully charged and needs to be charged more or is it due to the smaller pulley?
