kyleandhisIH
Today I got new Missouri plates for my green Scout II. I'm still trying to clean up the whole act, but two things still bother me about the setup .
1) my timing is reading 19* > 23* when running "best." This is based solely on drivability after countless trial "runs" of 10-15 miles trying to figure out where it liked the best. It will hardly run outside of this range, approx. 1/8th revolution "off" as far as degrees go.
I have loosened the distributor clamp and picked the body straight up and re stabbed, turning the rotor enough to notice a slight change in position once seated, compared top-down with a Mark for this purpose. I tried this twice at this point, but I guess I didn't get it right because I keep chasing the timing back into the same 19 > 23 range by rotating the body.
I guess it is also entirely possible that the pertronix unit I installed is somehow malfunctioning. I have mentioned in another post that the trigger's closest vertical face to the unit's magnet wheel seems to be far out of parallel with the shaft axis, and I have no dwell meter to try and figure if that's working properly.
I have used a timing light to look for changes across the entire set of wires at night, letting each one flash for a minute or so before changing. Nothing leaps out as inordinary.
2) manifold vacuum is impossible to read. Once I installed an IH-original 2bbl courtesy of the carb king, I had no carbureted passage to draw full vac from, which led to me trying a t-fitting in the brake booster hose. Instantly I saw huge fluctuations in the needle, as well as visibly cycling changes in needle action.
I have eliminated the possibility of the brake booster with a solid plug, and the fluctuation still seems to exist. For those who aren't enturely familiar, I'm thinking that the booster hose runs from the #8 intake runner, between the open plenum and head, and it's too cold to go look right now.
So, I'm not experienced with this sort of indication and don't know if this says something about my valve train, or perhaps just the particular flow of this intake, etc...
I just know that my Dad thinks it's 'missing' going down the road because of slight changes in speed, typically a burst of "decel" feeling. Much like a brief, but incomplete shift into neutral, which I guess could be the 727 that got rebuilt. Do the bands need readjustment after a break-in period after rebuilds?
I just want to be able to confidently drive the thing knowing I'm not causing long-term abuse by having it improperly tuned.
and the readings still basically convinced me that 154-156 is what it pumps.
