JohnnyC
Hey everyone. So... I picked up my first Scout about a month and a half ago, after watching extreme 4x4 on t.v. I thought they were working on a wierd looking Bronco. Low and behold, it was a Scout. I jumped on craigslist and found a whole mess of them. I gave four hundred dollars and a gun for it (could of found one cheaper). A buddy and I started ripping the guts out of it, then found rust, crud and crust. I started on the drivers side. Ripped out the rocker, floorboard, there was no wedge or body mount. So I started to make custom rockers out of 2x2 14g steel tubing. Welded it in, and now the door and top are so off alignment that I got discouraged and purchased another Scout. Talk about impulsive. I dont think my decision was wrong, because I found one with an almost perfect body. The po said it just needed a trans and a left fender. Got it for 550. When I finally found time to work on the new Scout found that it needed the carb rebuilt, I just took the new carb off the other Scout and slapped it on. Then I accidentally broke the out going fuel pump hardline, so I replaced it with the working pump from the other Scout. Filled the tank wit gas and still no fuel to the carb. And thats where I've stopped. On a side note I did get the engine started for about 5 seconds. I will start posting pics and entries that do not include run on sentences.
