Scout 800 Suspension Recommendation
JustWingingIt
Good morning.
I was looking at different suspension kits for my 800 build. I am thinking in order to remain SUA I'll have to piece parts together to create what I want. I'll be swapping in an 5.3 LS, and axles are going to be Scout II D44s.
My goal was to remain SUA and run a true 33" tire on my 800 build. Something along the sizes below.
285/75R17 = 33.8x11.2R17
295/70R17 = 33.3x11.6R17
275/80R17 = 34.3X10.8R17
Is there a recommended for IHPA products for this. All I read is to put on the CPT 2.5in kit, but I do not believe that will get me where I need for my tire size.
Thanks for the help.
We have all sorts of ways to lift your Scout higher either by modifying our existing CPT lift kit or running a completely different set of springs and hardware. I would suggest calling in to our retail store and talk with Michael. He can recommend a few different ways to go about this. Keep in mind the staff are pretty slammed right now due to our sale but he will get back with you. 530-274-1795
Good morning.
JustWingingit.....curious, I have a very similar need, I did the CPT Suspension Kit a number of years ago but looking for just a little more clearance as well with going SUA. Did you call Michael and what did he suggest? Thought I would take advantage of your newfound knowledge. Thanks, Jon
Negative Jon. You just reminded me I need to call back.
No need to crack the whip, we now have about 3' of snow up here in NE Idaho in the Teton's.....plenty of time to figure this stuff out. Needless to say, the Scout isn't the only 4WD in the household inventory. Thanks, Jon
So follow-up question because I may have put my project in a bind. I have my 800 completely disassembled. I have everything cutoff the frame, as well as all of the panels cutoff the tub and it sitting on a body cart. My assumption is that I should've done the long travel front suspension before removing anything else based on the instructions for the truck needing to be under weight to install the lift.
Probably a shot in the dark, but do you have any notes on drilling the reverse shackle hole location for the 4" lift RC long travel spring?
When I installed my first reverse shackle kit I did not have the body or engine on frame, in fact I had the frame upside down. which made welding in the front fangs much easier.
Once you have the front fangs located and welded in where you want them (where you want the axle centered based on which leaf spring center pin location you have, you can use a 2x4 between the spring eye and the frame and use a couple 10k lb ratchet straps to pull the spring into the frame/ 2x4 to give you an idea of where to locate the reverse shackle hole. You can play with shackle angles/ lengths from there.
Thank you for the reply. This process makes sense. I marked the frame where the axles were originally centered (aligned a laser with the pin and marked that location on the frame). So youre saying when installing the RS kit, essentially these would be the steps:
1. Flip frame over, then position RS front fangs.
2. Install front eyes of leaf springs in fangs.
3. Adjust front fangs based on new leaf spring center pin being aligned with original leaf center pin location on the frame.
4. Tack/weld in front fangs. Place 2x4 between rear spring eye and frame.
5. Load leafs at center pin location with 10k straps.
6. Position shackles to determine frame hole location.
7. Drill frame holes (do I need to sleeve the frame?)
8. Mount shackles.
Yup sounds good.
No you don't need to sleeve the frame as you're welding in a 2" piece of 1/4 wall DOM tube. I would follow IHPA's thread/ instructions on where to mount the front fangs. They do have pictures on here somewhere. It usually pushes the axle about an 1" forward of the original center pin point. (this is on a scout II but should be similar on an 800 as far as frame location. I believe IHPA uses a straight edge down from the front of the frame crossmember (behind the bumper) and keeps the bottom front edge of the fang inline with the crossmember.
With it 1" forward this allows for more clearance when the axle/ tires now swing backwards.
If there are original frame holes near where you drill through the frame I suggest filling those holes as it creates a weak point, mine cracked a bit there as I didn't fill them in originally. But I wheel mine pretty hard.
