1964 Scout 80, 4 wd, 152, 3 speed
Been driving it for a week & a half every day to work. Yesterday turned key to start position & it wouldn't crank. Gauges came up but that's it. Used screwdriver to jump starter solenoid & I was on my way. I figured I need a new starter solenoid so I swapped one in when I got home.
New solenoid didn't fix it. I found that if I took starter wire off back of key switch & touched it to battery wire on back of key switch (with key on), it would crank & start (as if I were turning the key). So no brainer, my key switch is bad.NOPE. Swap in a new switch & same problem. I have the key switch hanging out so I can simply touch the wires together to start it till I figure this out.
