A year ago, I rebuilt my 304 and it ran very well until I parked it this past summer. Getting ready for a trip last week, I lost oil pressure after about a 15 min drive. I have both the original and a aftermarket pressure gage and the lifters were making some noise.
I drained the oil and noticed a small red strand come out with the oil. I then removed the pan and found the pick up screen completely blocked with red fibers, opened the oil pump and it was clean, cut open the filter there were some fibers but not enough to plug the filter, I think.
I then reassembled and had great oil pressure 40 cold, 20 hot at idle, and no lifter noise. Took it on an all day trip with good pressure readings. Then the next morning, I immediately had zero pressure. Removed the pan once more and the screen is plugged.
I still can not be believe I left a rag in the engine. After the first pan removal and cleaning, I thought that I May have left it in the pan. Now, I wonder if I left it in the valley? Or? Never the less, my question is; should I keep cleaning the screen or bite the bullet and look in the valley as well? Or should I plan on completely disassembling, cleaning, and reassembling the engine. A complete tear down is not something I am wanting to do, but will if necessary.
Thanks in advance.
Tom
Thanks in advance.
Tom
