rear wheel bearings and seals
How many seals go in the rear wheel of a 76 Scout II Dana 44? I know there is one seal that goes in the axle shaft, but is there another one?
The mt-130 ihc parts catalog covering sii model years from '73-80, specifies two inner and two outer axle shaft seals per rear axle assembly.
The early scouts like my Dad's 73, had an inner seal. It went in the tube just behind the bearing. On these models the rear bearing was suppose to be greased every so many miles. You can guess how many people did that! They later did away with the inner seal and let the bearing run in gear oil.
