Question on Knobs....
ornelles
Hello,
before I break something, is there some trick to getting the knobs off the light switch and hood release? I see what looks like a filled in small hole, is there a screw down in there or do I just need to keep pulling on these things till they pop off?
Thanks,
Light switch --
there should be a "spring-loaded" "button" on the "top" (metal cover) of the switch. On IH, the switch May be mounted such that the button is pointing to the floor -- if you can bend yourself into position to look behind the dash.
Pull knob out (turning the headlights on); then, depress the button and the knob / shaft should pull out of the headlight switch.
Hood latch -- do not know -- look for a small set screw...?
