Part ID?
gato
Hi guys 63 Travelall 2wd and im trying to find out what this part that seems to be a hub that my power rear window wires are connected to. It is located under the driver side.
Thanks!
Mark
Appears to be a terminal block. Not familiar enough with the early ta's to tell you whether it is oe, but my guess is it is aftermarket.
Circuit breaker possible. All the early IH's did not have fuses, a relay was used. They pop like a fuses and reset in a few second/minute. Don't know the part number or exact name for it. If it is bad you can replace with a fused link.
